查看: 167|回复: 0
AutoPore IV 9500全自动压汞仪简介
2418
2441
200012478
发表于 2026-5-24 06:32:08 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
2026-05-24           环球过滤分离技术网            guolvfenlitech6
AutoPore IV系列压汞仪使用汞侵入法来测定总孔体积、孔径分布、孔隙率、密度和传输性。内置强大的数据处理和报告程序包,快速升压、灵活、可控的真空系统,和高性能的低/高压系统。
技术特点:孔径范围:0.003到 1000 nm;可选择2个低压站和1个高压站或者4个低压站和2个高压站,以满足多种样品的检测;高级别安全防护,即使在高压和有毒的物质汞环境下仍可放心使用;可选择压力33000 psi或者压力60000 psi型号;低噪音,高压系统;增强的数据处理包,包括弯曲度、渗透性、压缩系数、孔喉比、分形维数,Mayer-Stowe粒径分布等;可进行扫描模式或速率平衡模式操作;收集极高分辨率的数据;进汞或退汞体积精度优于0.1μL;封闭式汞系统-用汞量低。
Introduction:Micromeritics' AutoPore IV 9500 characterizes a material’s porosity by applying various levels of pressure to a sample immersed in mercury. The pressure required to intrude mercury into the sample’s pores is inversely proportional to the size of the pores. This is called mercury porosimetry, or often, “mercury intrusion.” The AutoPore IV series provides high-quality analysis data and comes with enhanced data reduction and reporting packages, faster pressure ramp rates, a more flexible and controllable vacuum system, and a redesign of both the low-and high-pressure generation systems.
Features:
The term "porosimetry" is often used to include the measurements of pore size, volume, distribution, density, and other porosity-related characteristics of a material. Porosity is especially important in understanding the formation, structure, and potential use of many substances. The porosity of a material affects its physical properties and, subsequently, its behavior in its surrounding environment. The adsorption and permeability, strength, density, and other factors influenced by a substance’s porosity determine the manner and fashion in which it can be appropriately used.
The mercury porosimetry analysis technique is based on the intrusion of mercury into a porous structure under stringently controlled pressures. Besides offering speed, accuracy, and a wide measurement range, mercury porosimetry permits you to calculate numerous sample properties such as pore size distributions, total pore volume, total pore surface area, median pore diameter, and sample densities (bulk and skeletal).
The AutoPore IV Series Mercury Porosimeters can determine a broader pore size distribution (0.003 to 1100 micrometers) more quickly and accurately than other methods. These instruments are enhanced with features that enable them to more accurately gather the data needed to characterize the porous structure of solid materials. They also offer new data reduction and reporting choices that provide more information about pore geometry and the fluid transport characteristics of the material.
<span]数据采集精度:进退汞体积精度小于0.1μL
主要功能及特色:
广泛用于储油岩、 耐热材料、石墨、炭材料、 树脂、 颜料、催化剂、 吸附剂、 药物、陶瓷、 薄膜、 燃料电池材料及其它多孔物质孔结构的研究。
可提供数据包括:
1、孔体积,比表面积,孔尺寸分布
2、真体积和真密度,堆体积和堆密度
3、孔弯曲度和弯曲因子
4、不同孔尺寸级的数目
5、孔喉比,每一个空隙度下孔腔对孔喉的比例等
压汞仪的操作规程:
1、打开电脑,然后打开氮气开关机压汞仪开关;
2、打开AutoPore IV 9500软件界面;
3、称取样品质量,将样品转入膨胀计,密封,称量;
4、将称量好的膨胀计放入低压仓;
5、在软件界面选择低压测试,填写相关信息,进行低压测试;
6、低压测试结束后,将注入汞的膨胀计放入高压仓,准备进行高压测试;
7、在软件界面选择高压测试,填写相关信息,进行高压测试;
8、高压测试结束后,将膨胀计从高压仓中取出;
9、打开膨胀计,倒出废汞和废样,将膨胀计清洗干净,放回原位;
10、关闭软件界面,关闭电脑,然后关闭压汞仪,最后将氮气瓶关闭。
注意事项:
1.由于压汞房环境潮湿,请及时更换抽湿机水箱;
2.操作过程中要严格遵守操作规范,提高压汞仪及配件寿命;
3.汞剧毒,在操作过程中,严格佩戴防护面具,穿防护服,操作小心谨慎,防止汞从膨胀计洒出;如汞不慎洒出,不要慌乱,及时采取相应措施,防止更多的汞挥发;
4.注意压汞房卫生整洁,物品摆放整齐,打造一个舒适的实验环境。
GMT+8, 2026-10-27 21:14 , Processed in 0.188574 second(s), 17 queries , File On.
