mito
查看: 1554|回复: 0
Trinitex W3000工业过滤基材
2443
2466
200012581
发表于 2018-5-14 22:07:48 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
2018-05-14  环球过滤分离技术网
Trinitex® W3000 is the first product on the Trinitex® Advance platform, designed to purify air industrial applications.
作为首款高级过滤Trinitex Advance系列,Trinitex® W3000 隆重登场,主要应用于工业过滤。
产品亮点
Key Features
01
更高效隔离空气中微粒
更好的颗粒隔离效果,减少受外界环境,如尘土颗粒与盐害的侵蚀,以更好的保护涡轮
Higher particulate removal efficiency, reducing corrosion and delivering better protection of the turbine against dust particles and salt
02
在同等减压环境下更高能效
帮助涡轮最大化输出功率的同时,降低能耗,在同等降压条件中表现更高的效率。
Higher efficiency at equivalent level of pressure drop – helping to maximize output and minimize energy consumption
03
高湿度环境中能更好地防止液体倒灌
潮湿环境中有效防止液体倒灌,减少带有高盐害的液体倒灌,同时也能在高湿度环境中有效限制压力下降的峰值。
Better performance in humid environments preventing liquid water ingress through filters, reducing penetration of waterborne salts and limiting pressure drop peaks during conditions of high humidity.
04
寿命更长久
更耐久的产品性能,即时在恶劣的环境中,都能应对自如。同时增加脉冲喷气机的洁净功能。
Better media durability and extended pulse jet cleaning properties – delivering longer filter lifetime in demanding environmental conditions。
来源于:奥斯龙明士克
GMT+8, 2026-11-10 20:12 , Processed in 0.307792 second(s), 18 queries , File On.
