年份
| 第一作者
| 标题
| 期刊/会议
| DOI
| 类
| 核心结论
2026
| Cha J.H. 等
| Acid-free gas-phase ammonia recovery from high-strength wastewater using UHMWPE hollow fiber membranes
| J. Water Process Engineering
| 10.1016/j.jwpe.2026.110810
| D
| UHMWPE 中空纤维膜用于无酸气态氨回收,拓展 UHMWPE 膜应用边界。
2026
| Holmann A. 等
| Point-of-use UPE membrane filter optimization for EUV chemically amplified photoresist
| Proc. SPIE (Adv. Lithogr. 2026)
| 10.1117/12.3090819
| A
| 新一代 UPE 孔径较前代缩小约 25%,在 imec 标准 EUV CAR / NXE:3400B / 32 nm pitch 下刻蚀后桥连缺陷最低;归一化孔径与桥连密度 R²≈0.97,滤器自身洁净度成为一阶约束。
2026
| Kim J. 等
| High-flux PE membranes modified with tannic acid–silane and EDTA for reusable metal-ion removal in ultrapure water production
| 10.1016/j.jwpe.2026.110504
| C
| 单宁酸–硅烷/EDTA 螯合改性高通量 UHMWPE 膜去除超纯水中金属离子,可重复使用(方法学参照)。
2025
| Basko A.V. 等
| Preparation of porous UHMWPE separators for Li-ion batteries via TIPS method
| J. Industrial and Engineering Chemistry
| 10.1016/j.jiec.2025.03.032
| B
| TIPS 法制备锂电用 UHMWPE 多孔隔膜,延续相图研究成果。
2025
| Basko A.V. 等
| Effect of Polymer Molecular Weight on UHMWPE Membranes Prepared via Controlled Swelling
| Polymers
| 10.3390/polym17152044
| B
| 首次考察分子量对「可控溶胀法」UHMWPE 超滤膜结构与性能的影响。
2025
| Guo Y. 等
| Multiscale structural evolutions of ultra-high molecular weight polyethylene porous membrane
| Review of Materials Research
| 10.1016/j.revmat.2025.100091
| B
| 首次系统分析链缠结–结晶–孔结构多尺度耦合:均匀缠结网络是均匀结晶、可控孔结构与拉伸演化的前提。
2025
| Kim W.I. 等
| Removal of Metal Ions in Spin-on Hardmask Using Functionalized Porous Silica Adsorbents
| Applied Sciences
| 10.3390/app15137185
| A
| 功能化多孔吸附剂去除旋涂硬掩模中金属离子,代表「化学特异性去除」而非孔径筛分路线。
2025
| Kohyama T. 等
| Exploration of UPE membrane technology in point-of-use EUV CAR photoresist filtration
| Proc. SPIE
| 10.1117/12.3051101
| A
| 面向 High-NA EUV 与 5 nm 以下节点开发新型 UPE 滤膜,强调 POU 过滤是抑制随机缺陷、达成良率的关键使能环节。
2025
| Kubo M. 等
| Dual-function filtration to improve on-wafer defectivity performance for EUV applications
| Proc. SPIE
| 10.1117/12.3050213
| A
| 兼具颗粒截留与化学选择性吸附的「双功能」滤膜降低 EUV 片上缺陷。
2025
| Xu J. 等
| Preparation of UHMWPE Hollow Fiber Membrane With High Permeability Using High Winding Speed
| J. Applied Polymer Science
| 10.1002/app.57032
| B
| 高卷绕速度工艺制备高渗透通量 UHMWPE 中空纤维膜。
2024
| Basko A.V. 等
| Thermally induced phase separation of UHMWPE mixture with dioctyl adipate: Competition of L-L phase separation and crystallization
| Thermochimica Acta
| 10.1016/j.tca.2024.179787
| B
| 热分析厘清液–液相分离与结晶竞争,支撑替代相图框架。
2024
| He J. 等
| Surface Modification of Ultra-High-Molecular-Weight Polyethylene and Applications: A Review
| Polymers
| 10.3390/polym16233431
| C
| UHMWPE 表面改性(接枝、等离子、涂层等)方法与应用系统综述。
2024
| Kohyama T. 等
| An update on the improvement in optimization of point-of-use filtration of metal oxide photoresists
| Proc. SPIE
| 10.1117/12.3009767
| A
| 金属氧化物 EUV 胶 POU 过滤优化的阶段性进展。
2024
| Kohyama T., Foubert P.
| Updated UPE filter design for point-of-use EUV CAR photoresist filtration for defect improvement
| Proc. SPIE
| 10.1117/12.3009768
| A
| R02 膜在膜厚不变下提高孔道曲折度以增强 gel 捕集;证明筛分机制主导桥连缺陷改善,方向为缩孔径、提均匀性、增曲折度。
2024
| Quan J. 等
| Tannic acid–APTES coated UHMWPE membrane for DCMD
| Separation and Purification Technology
| 10.1016/j.seppur.2024.128617
| C
| 单宁酸–硅烷涂层实现 UHMWPE 膜亲水/功能化改性。
2024
| Wang X. 等
| Preparation of UHMWPE/SiO2 hybrid porous flat membranes by template and TIPS methods
| 10.1016/j.seppur.2024.131304
| B
| 模板法+TIPS 制备 UHMWPE/SiO₂ 杂化平板膜,改善表面性质与透气性。
2024
| Xie D. 等
| 2.5 μm-Thick Ultrastrong Asymmetric Separator for Stable Lithium Metal Batteries
| Energy & Environmental Materials
| 10.1002/eem2.12746
| D
| 超薄高强非对称隔膜,体现 UHMWPE 非对称孔结构在电池领域的并行发展。
2023
| Hu T. 等
| Combined effects of nanoparticle and stretch-induced orientation on UHMWPE/TiO2 composite microporous membranes
| Polymer Composites
| 10.1002/pc.27346
| B
| TIPS+挤出流延+拉伸,纳米 TiO₂ 与取向协同调控结晶与膜性能。
2023
| Kohyama T. 等
| Continued optimization of point-of-use filtration for metal oxide photoresists to reduce defect density
| Proc. SPIE
| 10.1117/12.2657509
| A
| 延续 2021 工作,持续优化金属氧化物 EUV 胶 POU 过滤。
2023
| Pochivalov K.V. 等
| Controlled Swelling of Monolithic Films as a Facile Approach to the Synthesis of UHMWPE Membranes
| Membranes
| 10.3390/membranes13040422
| B
| 提出「致密薄膜可控溶胀」成膜新法,绕开 UHMWPE 高黏度熔体/溶液加工难题。
2023
| Zhang G. 等
| Preparation of reusable UHMWPE/TiO2 photocatalytic microporous membrane reactors
| 10.1016/j.seppur.2022.122515
| C
| UHMWPE/TiO₂ 光催化微孔膜反应器,可重复使用降解水中有机污染物。
2023
| Zhang Y. 等
| Defectivity reduction in EUV resists through novel high-performance Point-Of-Use (POU) filters
| Proc. SPIE
| 10.1117/12.2660389
| A
| 更细孔径+更优孔几何的 sub-1 nm HDPE 膜,配合 GC-MS/LC-MS/ICP-MS 洁净度表征,在 imec 16 nm L/S 验证 EUV 胶降缺陷。
2023
| Zhu Y. 等
| Construction and hydrophilic modification of dual-network structured nonwoven/UHMWPE composite membranes for water processing
| RSC Advances
| 10.1039/d3ra00920c
| C
| 双网络无纺布/UHMWPE 复合膜亲水改性,50 nm 微球截留近 100% 并具抗菌性。
2022
| Basko A.V., Pochivalov K.V. 等
| Current State-of-the-Art in Membrane Formation from Ultra-High Molecular Weight Polyethylene
| Membranes
| 10.3390/membranes12111137
| B
| 近 30 年 UHMWPE 成膜的权威综述:给出方法分类与「引入溶胀度边界线」的替代 TIPS 相图,指出均相溶液制备与膜收缩是两大核心难题。
2022
| Fang R. 等
| Defect Reduction with Advanced Lithographic Filter
| CSTIC 2022 (IEEE)
| 10.1109/cstic55103.2022.9856845
| A
| 先进光刻滤膜对缺陷密度的削减效果(国内会议,国际出版)。
2022
| Quan J. 等
| Construction of intrinsic superhydrophobic UHMWPE composite membrane for DCMD
| Journal of Membrane Science
| 10.1016/j.memsci.2022.120353
| D
| 本征超疏水 UHMWPE 复合膜用于直接接触式膜蒸馏。
2021
| Arzhakova O.V. 等
| Mesoporous Membrane Materials Based on UHMWPE: From Synthesis to Applied Aspects
| Membranes
| 10.3390/membranes11110834
| B
| 系统梳理 UHMWPE 介孔膜从合成到应用的路线与关键科学问题。
2021
| Aït-Haddou H. 等
| Novel functionalized membrane approaches to metal contamination control in advanced lithography filtration
| Proc. SPIE
| 10.1117/12.2584752
| A
| 功能化(离子交换/吸附型)膜用于先进光刻滤器痕量金属控制,标志「化学选择性去除」路线确立。
2021
| D'Urzo L. 等
| High performance filtration for bulk materials: a novel HDPE membrane filter designed for EUV Lithography
| Proc. SPIE
| 10.1117/12.2584064
| A
| 面向 EUV 的新型 HDPE bulk 滤膜,同时提升截留与洁净度(残余颗粒、金属、有机物)。
2021
| Fan L.-L. 等
| Preparation of Hydrophilic UHMWPE Hollow Fiber Membranes by Chemically Bounding Silica Nanoparticles
| Chin. J. Polym. Sci.
| 10.1007/s10118-021-2507-1
| C
| TIPS 中空纤维膜化学键合 SiO₂;VTMS 13%、pH 4、水解 6 h 时亲水/抗污染最优。
2021
| Guo Y. 等
| Constructing tunable bimodal porous structure in UHMWPE membranes with enhanced water permeance and retained rejection
| 10.1016/j.memsci.2020.118778
| B
| 构建可调双峰孔结构,在保持截留率的同时显著提高水通量——与产业侧「非对称孔」思路同构。
2021
| Liu R. 等
| Multifunctional Polydopamine Particles as a Thermal Stability Modifier to Prepare Antifouling Melt Blend Composite Membranes
| ACS Omega
| 10.1021/acsomega.0c04915
| C
| 聚多巴胺粒子作热稳定改性剂,熔融共混制备抗污染复合膜。
2021
| Quan J. 等
| Atmospheric Drying UHMWPE Membranes via Multiple Stage Extractant Exchange Drying Technique
| Advanced Fiber Materials
| 10.1007/s42765-021-00102-x
| B
| 多级萃取剂置换常压干燥,抑制 UHMWPE 膜干燥收缩与孔塌陷。
2021
| Wu A. 等
| Optimization of point-of-use filtration for metal oxide photoresist
| Proc. SPIE
| 10.1117/12.2583842
| A
| UPE 滤膜因截留效率高、光化学兼容性好被用于金属氧化物 EUV 胶,比较多种保留评级与膜设计后给出降缺陷 POU 方案。
2021
| Wu Y. 等
| Investigation on cavitation behavior of UHMWPE during stretching in wet process and dry process
| Polymer
| 10.1016/j.polymer.2021.124081
| B
| 对比湿法/干法拉伸中 UHMWPE 的成穴行为,解释孔结构演化差异。
2020
| Cao C. 等
| Sensitive phase separation behavior of ultra-high molecular weight polyethylene in polybutene
| Polymer Testing
| 10.1016/j.polymertesting.2019.106243
| B
| UHMWPE/聚丁烯体系相分离对组成高度敏感,为 TIPS 相图调控提供依据。
2020
| Cao X. 等
| Fabrication of Self-Lubricating Porous UHMWPE with Excellent Mechanical Properties via Rotary Sintering
| Polymers
| 10.3390/polym12061335
| D
| 旋转烧结制备自润滑多孔 UHMWPE,展示烧结成孔路线。
2020
| D'Urzo L. 等
| Defectivity modulation in EUV resists through advanced filtration technologies
| Proc. SPIE
| 10.1117/12.2560144
| A
| 不同先进滤膜/膜材组合可调制 EUV 胶缺陷密度。
2020
| Fei Z. 等
| Facile preparation of a crosslinked hydrophilic UHMWPE membrane
| 10.1002/app.49015
| C
| 交联法实现 UHMWPE 平板滤膜长效亲水化,提升水处理效率。
2020
| Liu R. 等
| The Construction of a Hydrophilic Inorganic Layer Enables Mechanochemically Robust Super Antifouling UHMWPE Composite Membrane Surfaces
| Polymers
| 10.3390/polym12030569
| C
| VTMS 偶联 SiO₂ 亲水无机层,赋予 UHMWPE 膜机械化学稳健的超抗污染表面。
2020
| Quan J. 等
| Air and Water Vapor Permeable UHMWPE Composite Membranes for X-Ray Shielding
| Ind. Eng. Chem. Res.
| 10.1021/acs.iecr.0c01162
| D
| UHMWPE/PET 网/CeO₂ 复合膜兼顾透气与 X 射线屏蔽。
2020
| Sha'rani S.S. 等
| Enhanced Proton Conductivity of Porous UHMWPE membrane with Graphene-based material for Vanadium Redox Flow Battery
| IOP Conf. Ser.: Mater. Sci. Eng.
| 10.1088/1757-899x/808/1/012024
| D
| UHMWPE 接枝 PVBC 制备液流电池用质子传导多孔膜。
2020
| Wang X.N. 等
| The Effect of Stretching on UHMWPE Microporous Film by Thermally Induced Phase Separation Method
| Materials Science Forum
| 10.4028/www.scientific.net/msf.993.906
| B
| TIPS 后拉伸用于优化 UHMWPE 微孔膜孔结构。
2020
| Wu A. 等
| Improving EUV underlayer coating defectivity using Point-Of-Use filtration
| Proc. SPIE
| 10.1117/12.2551647
| A
| POU 过滤有效降低 EUV 底层涂布缺陷。
2019
| Kohyama T. 等
| Filter technology developments to address defectivity in leading-edge photoresists
| Proc. SPIE
| 10.1117/12.2514974
| A
| 面向 N7 及更先进节点,通过滤膜设计同时改善缺陷率与拥有成本。
2019
| Sheng L. 等
| Effects of cooling process on the solid–liquid phase separation process in UHMWPE/liquid paraffin blends
| Polymer Bulletin
| 10.1007/s00289-019-02733-y
| B
| 冷却历程调控 UHMWPE/液体石蜡固–液相分离与最终孔结构。
2019
| Umeda T. 等
| Start-up performance and pattern defectivity improvement using 2nm rated nylon filter developed with lithography filtration expertise
| Proc. SPIE
| 10.1117/12.2515163
| A
| 2 nm 尼龙滤膜改善启动性能与图形缺陷,与 UPE 形成筛分/吸附互补。
2018
| Liu R. 等
| Surface modification of UHMWPE/fabric composite membrane via self-polymerized polydopamine followed by mPEG-NH2 immobilization
| 10.1002/app.46428
| C
| 聚多巴胺自聚合+mPEG-NH₂ 固定化改善 UHMWPE 复合膜亲水性与抗污染。
2018
| Zhao C. 等
| Preparation and properties of UHMWPE microporous membrane for lithium ion battery diaphragm
| 10.1088/1757-899x/324/1/012089
| D
| TIPS 配方与工艺对 UHMWPE 锂电隔膜结构/性能的影响规律。
2017
| D'Urzo L. 等
| Continuous improvements of defectivity rates in immersion photolithography via functionalized membranes
| Proc. SPIE
| 10.1117/12.2258582
| A
| 功能化膜(UPE 尺寸筛分+尼龙非筛分吸附)协同降低浸没式光刻缺陷率,并给出 LWR 与压差/流速工艺窗口。
2017
| Li R., Gao P.
| Nanoporous UHMWPE Membrane Separators for Safer and High-Power-Density Rechargeable Batteries
| Global Challenges
| 10.1002/gch2.201700020
| D
| 自增强复合 UHMWPE 纳米孔隔膜,兼顾电池安全性与高功率密度。
2017
| Umeda T. 等
| Metal reduction at bulk chemical filtration
| Proc. SPIE
| 10.1117/12.2257937
| A
| 与 POU 研究配套的 bulk 化学品过滤除金属,形成「bulk + POU」两级控制思路。
2017
| Varanasi R. 等
| Advanced lithographic filtration and contamination control for 14nm node and beyond semiconductor processes
| Proc. SPIE
| 10.1117/12.2260001
| A
| 面向 14 nm 及以下节点,系统给出过滤与污染控制的整体方案。
2017
| Varanasi R. 等
| Enhanced Cleaning for the Point-of-Use Filter and its Effectiveness on Wafer Defectivity in Immersion ArF Lithography
| J. Photopolym. Sci. Technol.
| 10.2494/photopolymer.30.639
| A
| 强化 POU 滤器清洗/预润湿可显著改善晶圆缺陷率,指向滤器安装与启动洁净度。
2016
| Li N. 等
| PVDF/UHMWPE/SiO2 hollow fiber membrane with network enhanced structure
| Reactive and Functional Polymers
| 10.1016/j.reactfunctpolym.2016.10.005
| B
| 共混+无机粒子网络增强的中空纤维膜路线,提升结构稳定性。
2016
| Liu R. 等
| Development and evaluation of UHMWPE/woven fabric composite microfiltration membranes via TIPS
| RSC Advances
| 10.1039/c6ra11456c
| B
| 低浓度(<8 wt%)UHMWPE/液体石蜡 TIPS 与织物复合,5 wt%、Mη=4×10⁶ 时 BSA 截留 76%、水通量 621 L m⁻²h⁻¹。
2016
| Liu R. 等
| Effect of Modified NanoSiO2 Agents on the Morphologies and Performances of UHMWPE Microporous Membrane via TIPS
| 10.4028/www.scientific.net/msf.848.726
| B
| KH570 改性纳米 SiO₂ 调控 TIPS 法 UHMWPE 微孔膜形貌与性能。
2016
| Umeda T. 等
| Metal reduction at point-of-use filtration
| Proc. SPIE (Adv. Lithography)
| 10.1117/12.2218400
| A
| POU 过滤环节对光刻化学品中金属离子的削减,是湿电子化学品金属污染控制的早期系统研究。
公开号/专利号
| 申请人
| 优先权年
| 公开年
| 技术主题
| 技术要点
| 置信
US20230356151A1 / US12343681B2
| FUJIFILM
| 2023
| 2025
| 化学液纯化/延续案
| Filter A(A1/A2/A3 滤芯)与 Filter B 串联的化学液过滤装置;UPE 明确性待核验。
| C
US20250136776A1
| W. L. Gore(页面未列申请人)
| 2023
| 2025
| 制备/延续申请
| Mw ≥2×10⁶ g/mol UHMWPE 制多孔制品,Gore 糊状加工路线延续案。
| C
US20240198261A1
| 德国发明人(申请人待核验)
| 2023
| 2024
| 其他应用/滤布
| 至少 25% 经纱采用 UHMWPE 的机织滤布,区分滤饼侧与滤液侧。
| B
CN116571104A/B
| 杭州科百特
| 2023
| 2023
| 制备/平行族
| 「一种 UPE 过滤膜及其制备方法和应用」,与 WO2024222404 同日申请的平行族。
| B
WO2024222404A1 / CN116571103A
| 杭州科百特过滤器材
| 2023
| 2024
| 制备/梯度孔 UPE 膜
| 两表面孔形不同(花边孔 vs 圆孔)、孔径梯度变化、层间连续纤维;PMI 平均孔径 2–100 nm,明确用于光刻胶与溶剂过滤。
| A
US20240343881A1
| 浙江兰德能源科技
| 2023
| 2024
| 制备/溶剂脱除
| 咪唑鎓类离子液体萃取剂,用于 UHMWPE 纤维与膜制备中脱除溶剂。
| C
US20230241557A1
| Entegris
| 2022
| 2023
| 功能化/除金属
| 正/负电荷交联单体涂覆膜组合,1 ppb 级 Li、B、Na、Al、Fe、Ni、Cu 去除率 >90%;权利要求以 PTFE 为主,UPE 归属待核验。
| C
WO2022229748A1 / US20240382905A1
| 3M Innovative Properties(后与 Solventum 关联)
| 2021
| 2022
| 改性/亲水化
| 含氨基+聚氧化烯+(甲基)丙烯酸酯的亲水单体涂覆 UHMWPE/聚酰胺膜并电子束固化,IgG 吸附 <150 µg/cm²。
| B
WO2022212412A1 / US20220323912A1
| Entegris
| 2021
| 2022
| 功能化/除金属
| UPE 多孔膜中掺入 5–50% 活性炭/炭黑等碳质材料,一步去除金属离子、酸、碱与有机污染物。
| B
US12502664B2 / US20220184595A1
| Entegris
| 2021
| 2025
| 功能化/除金属
| 强阳离子交换膜用于环己酮等酸敏感酮类溶剂除金属,同时抑制酮降解、色度与低聚物生成。
| C
WO2023040880A1 / CN113694745B
| 张春燕 / 科百特体系(权属待核验)
| 2021
| 2023
| 制备/高比表面积
| 对称 UPE 膜比表面积 ≥35 m²/g、10–60 nm 枝状连续纤维,兼具孔截留与吸附截留,面向光刻胶过滤。
| B
CN113926322A/B
| 杭州科百特
| 2021
| 2022
| 制备/低比表面积
| 比表面积 7–24 m²/g、IPA 泡点 0.15–0.65 MPa,对 20–200 nm 杂质截留 >95%,无效孔容少、易清洗。
| B
CN113209835A / CN113274889A / CN113332861A / CN113351033A / CN113398778B
| 杭州科百特科技 / 杭州泷泽过滤器材
| 2021
| 2021
| 制备/UPE 平板膜专利群
| 一批 UHMWPE 平板膜/滤膜/多孔膜及其制备工艺基础申请,构成科百特 UPE 膜专利群;被 WO2024222404 的 ISR 引为 X 类对比文件。
| A
US12059656B2 / US20220105476A1
| Entegris
| 2020
| 2024
| 功能化/除金属
| 配体改性多孔膜专用于胺类(去胶/刻蚀液)中金属污染物去除,可作 POU 除金属单元;UPE 归属待核验。
| C
WO2022094026A1 / US20220134293A1
| Entegris(据发明人团队推断)
| 2020
| 2022
| 制备/低析出
| 以 UHMWPE 为对象的聚烯烃滤膜,Ti/Al/Fe/Zn/Mg 总金属 <4 ppm(优选 <1 ppm),降低滤芯自身金属析出。
| B
US11772055B2 / US20210260537A1
| Entegris(权属变更待核验)
| 2020
| 2023
| 功能化/除金属
| 亚氨基二乙酸等多羧基配体改性滤膜,螯合去除湿法刻蚀/去胶液中的金属离子;UPE 归属待核验。
| C
US20200222859A1
| Entegris(据发明人团队推断)
| 2019
| 2020
| 制备/中空纤维
| UHMWPE(Asahi UH901/BM840=75/25)+ DBS/矿物油浆料挤出,液态金属骤冷制中空纤维多孔膜,泡点约为水骤冷膜 2 倍。
| B
CN111187441A
| 杭州科百特科技
| 2019
| 2020
| 制备/多孔材料
| 「一种 UPE 多孔材料制备工艺」,科百特较早的 UPE 材料侧申请。
| B
US20200101427A1 / US11623184B2
| 香港科技大学 HKUST
| 2019
| 2020
| 水处理/Janus 膜
| 0.1–12 µm 双轴取向纳米孔 UHMWPE 膜(孔隙率 65–75%、截留 >10 nm),亲水聚合物涂覆成 Janus 膜用于 MD/RO/FO。
| B
WO2020091974A1 / US12409423B2
| Entegris
| 2018
| 2020
| 制备/非对称孔
| 按密度筛选的 PE(含 HDPE)熔融挤出–骤冷制两面孔径非对称膜,0.03 µm 颗粒截留≥95%、孔隙率≥60%,含滤筒权利要求;被科百特引为对比文件。
| A
WO2019181440A1 / US11833475B2 / US12161973B2
| FUJIFILM
| 2018
| 2019
| 化学液纯化/串联过滤
| 串联 Filter A(UPE 多孔膜+覆盖表面的中性基/离子交换基树脂层)与不同 Filter B,解决单用接枝 UPE 膜时缺陷抑制不足;FUJIFILM 核心族。
| A
US20200384416A1
| FUJIFILM
| 2018
| 2020
| 化学液纯化/非对称孔
| 说明书明确多孔膜优选含超高分子量 PE(Mw 1×10⁶ 以上,优选 2–6×10⁶),涵盖非对称孔(open/tight side、hourglass),与尼龙纤维膜串联。
| B
WO2019181435A1
| FUJIFILM
| 2018
| 2019
| 化学液纯化/姊妹族
| 「过滤装置、精制装置、药液制造方法」姊妹族,被科百特 UPE 膜专利引为对比文件;具体 UPE 限定待核验。
| C
US20190308117A1 / US11198078B2
| FUJIFILM Electronic Materials USA
| 2018
| 2019
| 化学液纯化/装置
| 双系统循环过滤装置,第二级可用孔径低至 3 nm 的 UPE 滤芯,配合离子交换/离子吸附膜多级去除颗粒与金属。
| B
US20190076765A1
| PICOGRAM + 韩国原子力研究院 KAERI
| 2018
| 2019
| 其他应用/除铯
| UHMWPE 与铯吸附剂混合加热模压成预滤芯,兼具除铯与耐冲击、耐磨、耐化学性。
| A
US11052352B2
| 天津工业大学
| 2018
| 2021
| 制备/共混改性
| PVDF/UHMWPE 共混微孔膜及制备方法。
| B
US20190267594A1 / US12206064B2
| 香港科技大学 HKUST
| 2017
| 2019
| 制备/双轴取向纳米孔膜
| 双轴取向纳米孔 UHMWPE 膜及制备方法。
| B
US20200406201A1 / US11103833B2
| Entegris
| 2016
| 2020
| 改性/疏水脱气
| UHMWPE 膜拉伸+接枝全氟辛基丙烯酸酯,制高透气疏水小孔膜,可 γ 灭菌,用于 venting、脱气与膜蒸馏。
| B
US20190219923A1
| FUJIFILM
| 2016
| 2019
| 化学液纯化/杂质规格
| 药液、收纳体与灌装方法;滤材列举含超高分子量聚烯烃,控制金属杂质 ≤50 mass ppt。
| B
WO2016081729A1 / US10792620B2
| Entegris
| 2014
| 2016
| 改性/接枝
| 双光引发剂 UV 接枝中性或离子交换基团到非对称 UHMWPE 微孔膜;泡点 78–160 psi、10 s 内水润湿、水通量≥未接枝膜 50%;基石专利。
| A
US20160082398A1
| TEIJIN 帝人
| 2014
| 2016
| 制备/共混 TIPS
| UHMWPE(4.6×10⁶)+HDPE(5.6×10⁵) 共混 TIPS 微孔膜,70 nm 聚苯乙烯粒子捕集率 ≥90%、水通量 1.21–2.90 mL/min·cm²、泡点 0.40–0.65 MPa。
| B
US20160297937A1 / US10577468B2
| W. L. Gore & Associates
| 2014
| 2016
| 制备/糊状挤出拉伸
| 高结晶 UHMWPE(≥5×10⁵ g/mol、焓 ≥190 J/g)润滑→压制带材→低于熔点拉伸,形成 node-fibril 微孔膜,孔隙率 ≥25%(可达 60%)。
| B
US10576466B2 / US20150083667A1
| 2013
| 2020
| 滤芯结构/复合介质
| 50–250 µm 离子交换树脂粉+UHMWPE 粘结剂(可加活性炭)复合过滤介质;授权落在窗口内。
| B
US20140048741A1 (WO2012122022A1 同族)
| 2011
| 2014
| 历史/烧结基体
| 三种不同形貌 UHMWPE 颗粒共烧结成多孔基体,分散 20–90 wt% 功能化粒子。
| B
US8205755B2 / US20070221569A1
| 2007
| 2012
| 历史/碳块滤芯
| UHMWPE 作粘结剂的活性炭块滤芯,去除三卤甲烷与痕量 VOC。
| A
US8906539B2 / US9287542B2
| Toray Battery Separator Film / Toray Tonen
| 2007
| 2015
| 历史/锂电隔膜
| 多层聚烯烃微孔膜,表层 UHMWPE(Mw≥1×10⁶) ≥8%、内层 ≤7%,汞压入孔径呈双峰分布。
| B
US6649064B2 / US20020125189A1
| Millipore / Mykrolis
| 2002
| 2003
| 历史源头
| UPE 粒子去除膜固定螯合配体,净化 HF/HCl 等酸性水溶液中的金属离子。
| A
US6447684B1 / US20010042715A1
| Millipore / Mykrolis + IBC
| 2001
| 2002
| 历史源头
| UHMWPE 粒子截留膜固定大环螯合配体,同步去除超纯水中金属离子与颗粒——Entegris UPE 除金属技术源头。
| A
US6302934B1
| Nitto Denko
| 1999
| 2001
| 历史/洁净滤材
| 多孔 UHMWPE 膜与多孔 PTFE 膜层压替代无纺布支撑,低发尘、DOP/BHT/DBP ≤2 ppm,用于半导体洁净环境。
| B
US6387271B1
| Pall
| 1998
| 2002
| 历史源头
| 亲水 UHMWPE 折叠膜滤芯去除电厂凝结水含铁微粒,长周期反洗。
| A
