ProcessGard®PS Plus过滤器具备高通量及优化截留能力
nanotech3
2021-4-16 08:19
2021-04-16 环球过滤分离技术网 nanotech3
因应Display行业的市场需求,Entegris推出新款ProcessGard®PS Plus液体过滤器,此过滤器由我们的杭州工厂生产,除了大幅提升我们的供货能力,同时助力我们的客户缩短产品上市时间。
[attach]4716[/attach]
应用
Industry: FPD, HDD, Chemical, Ink & UPW facilities
Filtration of weak acids, bases and ultrapure DI water for cleaning processes and in DI water facilities
优势及效益
[attach]4715[/attach]
Asymmetric PES
membrane structure
低压差
适用于高通量工艺
Hydrophilic PES
membrane
不需要预湿处理
更换速度加快,延长设备运行时间
Polypropylene
support, core & cage
优异的化学相容性
实现多种应用
SPECIFICATIONS
Retention rating
0.05, 0.1, 0.2, 0.45, 1.0 μm
Material
Media: Hydrophilic polyethersulfone
Support: Polypropylene
Sleeve, end caps: Polypropylene
O-ring (AS568-222): EPDM, FKM, E-FKM
Gasket (Code F): EPDM, FKM
Maximum operating conditions
Maximum forward differential pressure: 0.4 MPa at 25°C (77°F)
Maximum reverse differential pressure: 0.25 MPa at 25°C (77°F)
Maximum operating temperature: 90°C (194°F)
[attach]4717[/attach]
来源于:Entegris,侵权告删
